This command shows the current captive portal configuration for web-redirects, L4 listening ports, and rule use space programming.
redirect_index | Shows the particular web redirect index indicated (1–10). |
all | Shows all web redirect indexes. |
listening | Shows captive portal HTTP listening L4 ports. |
web-redirect | Shows web redirect information. |
rule-use | Shows captive portal rule use. |
N/A
The following example shows the currently configured captive portal L4 listening ports:
# show policy captive-portal listening Captive Portal Listening Ports: 55 33 22
The following example shows the currently configured captive portal servers from all web-redirect indexes:
# show policy captive-portal web-redirect Web-redirect Index: 1 Server Index: 2 Server Status: enabled Server URL: http://192.168.1.3:5552/path/to/use Web-redirect Index: 10 Server Index: 2 Server Status: disabled Server URL: http://111.222.22.33:802/path/to/use
The following example shows all of the captive portal servers at web-redirect index 1 (regardless of configuration):
# show policy captive-portal web-redirect 1 Web-redirect Index: 1 Server Index: 1 Server Status: disabled Server URL: Server Index: 2 Server Status: enabled Server URL: http://192.168.1.3:5552/path/to/use
The following example shows the entire captive portal configuration:
# show policy captive-portal Captive Portal Listening Ports: 55 33 22 Web-redirect Index: 1 Server Index: 1 Server Status: disabled Server URL: Server Index: 2 Server Status: enabled Server URL: http://192.168.1.3:5552/path/to/use Web-redirect Index: 2 Server Index: 1 Server Status: disabled Server URL: Server Index: 2 Server Status: disabled Server URL: Web-redirect Index: 3 Server Index: 1 Server Status: disabled Server URL: Server Index: 2 Server Status: disabled Server URL: Web-redirect Index: 4 Server Index: 1 Server Status: disabled Server URL: Server Index: 2 Server Status: disabled Server URL: Web-redirect Index: 5 Server Index: 1 Server Status: disabled Server URL: Server Index: 2 Server Status: disabled Server URL: Web-redirect Index: 6 Server Index: 1 Server Status: disabled Server URL: Server Index: 2 Server Status: disabled Server URL: Web-redirect Index: 7 Server Index: 1 Server Status: disabled Server URL: Server Index: 2 Server Status: disabled Server URL: Web-redirect Index: 8 Server Index: 1 Server Status: disabled Server URL: Server Index: 2 Server Status: disabled Server URL: Web-redirect Index: 9 Server Index: 1 Server Status: disabled Server URL: Server Index: 2 Server Status: disabled Server URL: Web-redirect Index: 10 Server Index: 1 Server Status: disabled Server URL: Server Index: 2 Server Status: disabled Server URL: http://111.222.22.33:802/path/to/use
# show policy captive-portal rule-use Captive Portal Rule Use: Reserved
This command was first available in ExtremeXOS 22.3.
The rule-use option was added in ExtremeXOS 30.4.
